Old 01-02-2013, 09:19 PM   #1
mount into cinder block
want to mount 2x4 made shelves to cinder block walls , will carry heavy
weight
stevefau is offline   Reply With Quote
Old 01-02-2013, 09:40 PM   #2
Far better to make a whole shelving unit that stands on the floor.
If you want shelves instead one way I've done it and it was super strong is make a 2 X 4 frame, attach whatever you want to the top of it, plywood, OSB, Advantec MDF.
Mount it to the wall using long Tap Cons or lags and lead anchors.
Add some 2 X 4 supports under it cut at 45 deg.
I built the whole thing with ceramic coated decking screws.
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 01:26 PM
Concrete (Cinder) Block Barebones Home : Seeking Advice granadaCoder Building & Construction 11 08-11-2012 08:03 AM
Insulate Top of Cinder block wall HooKooDooKu Building & Construction 0 01-20-2010 11:58 PM
Fire blocking a wood stud wall built against cinder block. BasementVirgin Building & Construction 1 10-06-2009 12:02 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
