-   -   mount into cinder block (http://www.diychatroom.com/f19/mount-into-cinder-block-168084/)
stevefau 01-02-2013 08:19 PM
want to mount 2x4 made shelves to cinder block walls , will carry heavy
weight
joecaption 01-02-2013 08:40 PM
Far better to make a whole shelving unit that stands on the floor.
If you want shelves instead one way I've done it and it was super strong is make a 2 X 4 frame, attach whatever you want to the top of it, plywood, OSB, Advantec MDF.
Mount it to the wall using long Tap Cons or lags and lead anchors.
Add some 2 X 4 supports under it cut at 45 deg.
I built the whole thing with ceramic coated decking screws.
