The Most Economical House Width .. ? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-09-2010, 12:21 PM   #1
The most economical house width .. ?
Are there standard widths to consider when choosing a house design that would make the construction costs most economical in relation to lumber costs, rafter size, wall height... etc
I am looking at building (or having built) a two story cabover , If you google Penrod, this home is very close to what I am after. I would like to know if there is a width that would be best to use if I wanted to go wider than 30 feet.
Ragman is offline   Reply With Quote
Old 04-09-2010, 09:44 PM   #2
Rewards Points: 5,336
You might want to research manufactured housing to minimize material waste.
Ron
Old 04-10-2010, 01:13 AM   #3
Rewards Points: 1,092
good point
Remember when we used to laugh a pre-fab housing? A few years ago I checked into Nelson Homes, as my son was starting to build and I wanted to get it over with, but do a good job. I went around and looked at several of their houses, and was impressed. Window and door RO's were rectangular, all studs were cut off square, wood was quality, etc. When you think about it, if a plant gives a fat rat's, why can't they knock out a wall better than a person can from scratch? I have not looked at other manufacturers, but I would sure look into some if I were putting up a somewhat standard house. I have no idea if they do double-wall, super-insulated, etc, but if you are doing a stick house with one wall, one of the pre-fab places may be able to deliver walls that a few folks can stand up in a few days. Nelson provides (or did) everything to get you weather proof, and if you can do that quickly w/ quality stuff, that is worth a fortune.
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 05:48 AM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 10:09 PM
Deck Ledger To House Osb Rim Joist munson_11 Building & Construction 7 04-19-2008 12:41 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
