Mortar Shower Floor DIY Or NOT? - Building & Construction - Page 4 - DIY Chatroom Home Improvement Forum
Old 02-19-2013, 01:36 PM   #46
"You can do anything"-Mom
brockmiera's Avatar
So I pieced it out on Amazon and came up with $360 for the following
Schluter Kerdi Adaptor Drain Stainless-ABS Version
SCHLUTER KERDI-BAND - 5" X 33'
SCHLUTER KERDI INSIDE CORNER - 4 UNITS
Schluter Kerdi Mixing Valve Seal 4-1/2"
Schluter Kerdi Pipe Seal 1/2"
SCHLUTER KERDI - 108 SQFT
Does this sound about right if I'm going to use bricks for the curb and sand / mud mix for the pan?
brockmiera is offline   Reply With Quote
Old 02-19-2013, 02:16 PM   #47
Tileguy
JazMan's Avatar
Rewards Points: 412
Ok, so you have no drain and no tray. That's worth about $225 +-
Edit: Actually you may have a drain, but no tray. They package these things 25 different ways. Do you need the adaptor?
Sound good in your case. You're just missing 2 outside corners or you forgot to mention them. How about the adaptor? Are you converting a traditional drain in place?
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
brockmiera (02-19-2013)
Old 02-19-2013, 02:55 PM   #48
brockmiera's Avatar
Jaz
I thought the drain / adaptor assembly was the drain, weep flange, and all. Am I mistaken?
My brain is fried. what do I need the outside corners for?
I have a 2" PVC drain in place now.
This is what comes with the drain - It costs 111.19 on Amazon
Product Features
Includes: 4 inch square gate, height adjustment collar, ABS bonding flange and adaptor ring
Includes: Kerdi-Kereck Pre-formed corners (4 inside + 2 outside)
Includes: (1) Kerdi Pipe seal 3/4" and (1) Kerdi mixing valve seal 4-1/2"
Includes: Installation DVD & Handbook. Kerdi Membrane Template, (1) Tube of Kerdi-Fix 100g
Finish: Stainless Steel
Old 02-19-2013, 03:13 PM   #49
Tileguy
JazMan's Avatar
Rewards Points: 412
You don't need an adaptor if you have a 2" riser. You shouldn't need the Kerdi Fix either. Good to have though. The adaptor is used if you have an old 2 piece drain and are not removing it and installing the 2" pipe riser. But you have the 2" riser.
You need the outside corner to seal the top of the curb where it meets the side walls.
OK, I see the one you bought on Amazon. $111.99
Jaz
kimbhoot (02-19-2013)
Old 02-19-2013, 03:33 PM   #50
brockmiera's Avatar
Jaz
Ok that all makes sense. So regular drain, out/in side corners, membrane, band, mixer cover, spout cover, unmodified thinset, trowell.
What size trowel do I need for the membrane?
Old 02-19-2013, 04:02 PM   #51
Tileguy
JazMan's Avatar
Rewards Points: 412
A Kerdi trowel has 1/8" square notches. It's hard to find 1/8" in tile department, try the hardwood department. They sell Kerdi trowels but way expensive.
Jaz
The Following 2 Users Say Thank You to JazMan For This Useful Post:
brockmiera (02-19-2013), kimbhoot (02-19-2013)
Old 02-19-2013, 04:10 PM   #52
brockmiera's Avatar
Jaz
Thanks Jaz! I know you don't have to spend this much time helping out us newbies so please know it is very appreciated!
Old 02-19-2013, 07:20 PM   #53
Tileguy
JazMan's Avatar
Rewards Points: 412
You're welcome!
Jaz
Old 02-20-2013, 02:17 PM   #54
Jaz,
Did you get a chance to look at the ebay listing I sent? please let me know if that covers it all so I can go ahead and purchase it.
Thanks for all your help.
kimbhoot is offline   Reply With Quote
Old 02-20-2013, 04:20 PM   #55
Tileguy
JazMan's Avatar
Rewards Points: 412
Kim,
Yes, the measurements you listed in post #41 will be covered by one of the Kerdi Shower Kits, with some to spare. I didn't see a listing though.
Jaz
Old 02-20-2013, 10:54 PM   #56
Kim,
Jaz
this is the one I was talking about.
http://cgi.ebay.com/ws/eBayISAPI.dll...m=310515482804
Old 02-20-2013, 11:13 PM   #57
Tileguy
JazMan's Avatar
Rewards Points: 412
Ok, that's the regular kit. You're good.
Jaz
kimbhoot (02-21-2013)
Old 02-22-2013, 07:29 PM   #58
brockmiera,
when you have the work in progress, do post some photos.
Old 02-22-2013, 08:24 PM   #59
brockmiera's Avatar
Originally Posted by kimbhoot View Post
brockmiera,
And you too!
Mortar shower pan over concrete Bad4you77 Kitchen & Bath Remodeling 4 03-09-2012 07:11 AM
Piece of junk, leaky shower. How can I improve it? JustinEllard Plumbing 4 10-05-2010 08:45 AM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 09:10 AM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
