Old 03-13-2010, 06:31 PM   #1
mortar for repairing chimney
I'm hoping to attach a top-mount multi-flu chimney cap to this chimney.
Before doing so, its pretty obvious I need to patch up the mortar cap. Any tips on what type of mortar to use for this? (I will need to drill ceramic screws into it, to attach the chimney cap.)
mortar for repairing chimney-img_0014.jpg   mortar for repairing chimney-img_0012.jpg
kelley4180 is offline   Reply With Quote
Old 03-13-2010, 06:59 PM   #2
Master General ReEngineer
Bondo's Avatar
Ayuh,... The WHOLE Chimney needs Repointing, not Just the cap...
I'd think type S mortar, but somebody will know for sure...
Bondo is online now   Reply With Quote
Old 03-14-2010, 10:20 AM   #3
if there is no flue in there you need to look into new liners before those brick fall on the inside and block air flow
The older I get the better I was
Old 03-14-2010, 02:20 PM   #4
S type mortar? OK, I'll look into that.
There actually is a flu liner in there. Strangely, it only extends to about 16 inches below the top of the chimney. So, as a result, the last 5-6 rows of bricks are indeed exposed. I was hoping to put some mortar in there to strengthen those "unlined" brick rows.
Yes, repointing is on the to-do list for the spring. Good observation.
Old 03-14-2010, 06:04 PM   #5
concretemasonry's Avatar
The lack of flues in the upper portion could have accelerated the deterioration.
When you rebuild put in the flues with the proper mortar (not Type S for the flues). This way you will have a projection to slope your crown down from and attach a cap to.
concretemasonry is offline   Reply With Quote
Old 03-14-2010, 08:46 PM   #6
You need to extend the flue pipes out of the chimney. Also for the wash on the top of the chimney I always use a portland/sand mix never mortar.
NJ Brickie is offline   Reply With Quote
Old 03-15-2010, 02:05 AM   #7
Contractor
Brickie's Avatar
The International Residential Code (IRC) and the International Building Code (IBC) require that flue liners be laid with refractory mortar conforming to ASTM C 199.
Northwest Indiana Masonry
Old 03-15-2010, 11:01 AM   #8
Any tips on a product that would work to retrofit the last 16 inches of each flu with a liner? As mentioned, there is ceramic in there, but it just doesn't come up to the top.
Old 03-15-2010, 11:09 AM   #9
Concrete & Masonry
Yes, clay flues liners, just like the ones below, more than likely. Any masonry/brick yard should have them in the appropriate size. It may require you to remove some brick though, depending on how it's built. And as stated, refractory cement that's rated for exterior use.
jomama45 is online now   Reply With Quote
Concrete block Chimney problems scoggy Building & Construction 0 03-09-2010 08:00 PM
Cosmetic mortar coating over chimney. How thick? meltdowndave Building & Construction 0 11-14-2009 06:21 PM
Chimney repair: rebuild or repoint? cloud9 Building & Construction 33 09-22-2009 10:12 PM
Painting exterior brick with latex? hellothere123 Painting 10 09-19-2008 09:50 AM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing 6 03-07-2008 04:12 PM
