-   -   mortar for repairing chimney (http://www.diychatroom.com/f19/mortar-repairing-chimney-66710/)
kelley4180 03-13-2010 06:31 PM
2 Attachment(s)
I'm hoping to attach a top-mount multi-flu chimney cap to this chimney.
Before doing so, its pretty obvious I need to patch up the mortar cap. Any tips on what type of mortar to use for this? (I will need to drill ceramic screws into it, to attach the chimney cap.)
Bondo 03-13-2010 06:59 PM
Ayuh,... The WHOLE Chimney needs Repointing, not Just the cap...
I'd think type S mortar, but somebody will know for sure...
tpolk 03-14-2010 10:20 AM
if there is no flue in there you need to look into new liners before those brick fall on the inside and block air flow
kelley4180 03-14-2010 02:20 PM
S type mortar? OK, I'll look into that.
There actually is a flu liner in there. Strangely, it only extends to about 16 inches below the top of the chimney. So, as a result, the last 5-6 rows of bricks are indeed exposed. I was hoping to put some mortar in there to strengthen those "unlined" brick rows.
Yes, repointing is on the to-do list for the spring. Good observation.
concretemasonry 03-14-2010 06:04 PM
The lack of flues in the upper portion could have accelerated the deterioration.
When you rebuild put in the flues with the proper mortar (not Type S for the flues). This way you will have a projection to slope your crown down from and attach a cap to.
NJ Brickie 03-14-2010 08:46 PM
You need to extend the flue pipes out of the chimney. Also for the wash on the top of the chimney I always use a portland/sand mix never mortar.
Brickie 03-15-2010 02:05 AM
The International Residential Code (IRC) and the International Building Code (IBC) require that flue liners be laid with refractory mortar conforming to ASTM C 199.
kelley4180 03-15-2010 11:01 AM
Any tips on a product that would work to retrofit the last 16 inches of each flu with a liner? As mentioned, there is ceramic in there, but it just doesn't come up to the top.
jomama45 03-15-2010 11:09 AM
Yes, clay flues liners, just like the ones below, more than likely. Any masonry/brick yard should have them in the appropriate size. It may require you to remove some brick though, depending on how it's built. And as stated, refractory cement that's rated for exterior use.
