Mortar Repair - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-31-2010, 11:22 AM   #1
Mortar Repair
Hello, I have a porch with mortar over brick walls. The mortar began cracking and moisture got behind it causing it to get soft in some areas and it is now falling off. Behind it is sand but the outter part is hard. Can I just get rid of the loose parts that are easy to remove and repair those areas with new mortar. What kind should I use - is Type N ok? How do I apply it and make it stick to the wall? What consistency should it be? Thanks for any help.
Missfix is offline   Reply With Quote
Old 07-31-2010, 08:18 PM   #2
Rewards Points: 5,336
Mortar is a material that is interspersed with a manufactured material such as brick or block. Take a picture of your situation.
Ron
Old 07-31-2010, 08:39 PM   #3
Mortar Repair
Thanks for responding Ron. Will take a picture tomorrow and post it so you can see what's happening.
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 08:49 AM
How to repair crumbling cement and mortar? jerseyguy1996 General DIY Discussions 14 08-01-2010 10:49 AM
Plan to install new fiberglass tub; questions about process for mortar underneath lazzlazz Kitchen & Bath Remodeling 1 05-02-2010 04:53 PM
Chimney repair: rebuild or repoint? cloud9 Building & Construction 33 09-22-2009 09:12 PM
Basement Concrete Block Mortar Seepage Advice Nightcrawler Building & Construction 6 09-22-2009 08:57 PM
