Mortar Removal - Next Part Of The Story Pls. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-20-2009, 05:28 PM   #1
Rewards Points: 91
mortar removal - next part of the story pls.
Well, we've begun experimenting with removing the mortar from bricks. For those who missed the previous post, I have about a thousand bricks that I need to remove the mortar from. At 20 minutes per brick, I'm going to be doing this for a long time.
I'm using a pneumatic hammer on a Campbell Hausfeld HL4101.
Gallon Capacity: 8 Gallons
Max PSI: 125 PSI
SCFM @ 40 PSI 4.3 SCFM
SCFM @ 90 PSI 3.7 SCFM
Running HP 1.3
Voltage 120V
The problem is that this compressor won't turn off. All the while I'm working on a brick, this thing creats a real racket that keeps going until 5 minutes after I put the pneumatic hammer down.
So, the question now becomes what size/kind of compressor should I be using? My little Makita MAC700 is more powerful than the HL4101 but lacks the tank size. I look at other compressors and they're all over the place, from 1.3HP and 40 gallons up to 5HP and 20 gallons.
The pneumatic hammers are all over the place from 3 SCFM to 6 SCFM. I'm using in-line filtering/drying/lubricating and I'm running 90 psi line pressure.
Any insight would be appreciated.
Allthunbs
Allthunbs is offline   Reply With Quote
Old 06-20-2009, 05:43 PM   #2
Rewards Points: 4,750
it does turn off but just takes 5min to pump back up til the pressure control disphram clicks,,, hook both compressors up to a common reservoir tank,,, pressure'll be the same but you'll have more cfm's.
20 minutes seems very long,,, are you using a 2" brick chisel & putting the bricks on a sturdy bench jig ? ? ?
Old 06-21-2009, 07:50 AM   #3
Rewards Points: 91
Interesting, I'll have to try that.
I'm using a 1" chisel and the bench is two saw horses with a board nailed to them. Doesn't move around or bounce so it seems fine to me. I'm going to put a fence on tomorrow and try that. Any other suggestions?
Allthunbs
mortar removal Allthunbs Building & Construction 8 05-26-2009 08:19 AM
Mortar bed removal from block wall Douger_F Building & Construction 8 04-15-2009 07:47 AM
Mortar removal from salvaged brick. Rem8 Building & Construction 8 07-20-2008 07:05 AM
Lead paint removal Luken8r Painting 3 05-15-2008 07:05 PM
2x100a sub on service main jambud Electrical 17 03-12-2008 09:31 AM
