Mortar Liquid Bonding Agent Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-03-2008, 11:43 PM   #1
Rewards Points: 150
mortar liquid bonding agent question
i am patching some spots in a stucco house. it says on the bottle to apply with a brush to the hole. then it talks about another method of using the bonding agent instead of water when mixing the mortar. should i do both to get the mortar to adhere best? and what is this slurry they are talking about?
drewhart is offline   Reply With Quote
Old 11-06-2008, 07:45 PM   #2
Rewards Points: 150
if i were me, i would still not know the answer to this question.
Old 11-06-2008, 08:04 PM   #3
Rewards Points: 1,220
You can do both or either, but if you add it to the mortar, you need to dilute it at least 50%.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 11-06-2008, 08:05 PM   #4
Hi. Believe me I'm no masonry expert, but there are bonding agents which can be used to provide better adherance of new concrete to old.I just used some myself,mine was made by Sacrete and it was with the masonry stuff at Lowe's. It can be mixed into your concrete mix or,as you referred to,mixed up separately into a slurry and applied to the old masonry prior to the new. It comes in a one gallon bottle with complete and simple instructions on the bottle. Good luck.
white29 is offline   Reply With Quote
Old 11-06-2008, 08:11 PM   #5
Rewards Points: 150
i'm trying to patch some areas in a stucco house. should i add some portland cement and sand to the mortar mix, or do you think plain mortar is ok for the repair?
Old 11-06-2008, 08:45 PM   #6
Again,I'm no masonry expert and I've never had any experience with stucco. I have had a lot of success using vinyl patching compounds for surface patching concrete. These are dry concrete mixes which are fortified with vinyl fibers for added strength and elasticity.I would recommend that you look into these,very easy to use and tough. They are made by several company's,Quick-crete and Thorocrete come to mind. Lowe's,HD or any local building supply should have them.
Basement Wall Mortar rory535 Building & Construction 16 08-06-2009 10:39 AM
Mortar removal from salvaged brick. Rem8 Building & Construction 8 07-20-2008 08:05 AM
Bonding & Ground Rod Question bradsguns Electrical 3 06-13-2008 01:55 PM
Tile underlayment - mortar bed question Richo Flooring 10 01-01-2008 06:54 PM
