More ?? On Basement Finishing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-23-2006, 09:46 AM   #1
More ?? on basement finishing
Moderators please more if this is in the wrong forum.
I finished waterproofing my walls with Zinser Watertight. If I put up insulation do I need a vapor barrier? Or can I install some of the pink foam board type insulation and not use a vapor barrier?
I've read arguements going both ways, some say I need it, some say I don't. Any help would be wonderful.
nesparky95 is offline   Reply With Quote
Old 09-23-2006, 09:57 AM   #2
I'd say yes. I've built for 30 years and am still unsure. All basements have different levels of moisture penetration. I don't think it can hurt in any case. I've been just using that 1mil painters plastic. It is cheap and goes up quick. Good luck.
I hung out at Hastings College in 1971. I love Nebraska and the people that live there.
K2eoj is offline   Reply With Quote
Old 09-23-2006, 01:06 PM   #3
General Contractor
If you stud the wall out it might be best to install batt-type insulation in the cavities, then install an air/vapor barrier.
fqp25 is offline   Reply With Quote
Old 09-24-2006, 02:15 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
If you do use the the batt-type insulation:
....and you install the kind that already has a paper vapor barrier (i.e.- Paper faced), do not install an additional vapor barrier.
Also, make sure that the vapor barrier faces towards the warm side (living space).
- Build Well -
Old 09-24-2006, 04:04 PM   #5
If I go with the foam board type insulation will I need a vapor barrier?
Old 09-24-2006, 04:43 PM   #6
Yes, Even if you use the foam board, you should have a vapor barrier. Same application as with batt insulation...facing the warm side.
- Build Well -
Old 09-24-2006, 07:06 PM   #7
Smile
Thanks, I'll get the hang of this basement finishing thing yet!
Basement finishing cost estimate Bill46 Off Topic 8 10-01-2010 07:16 PM
How to 'start' finishing the basement... mcvane Building & Construction 18 06-04-2007 08:28 AM
A newbie basement finishing project DIY4EVER Building & Construction 6 05-11-2007 09:48 AM
Finishing Basement, How to run a heat duct? hyper Remodeling 6 02-23-2007 03:46 PM
Finishing basement - electrical code ??? normwannabe Electrical 1 01-23-2006 07:48 PM
