More ?? on basement finishing
Moderators please more if this is in the wrong forum.
I finished waterproofing my walls with Zinser Watertight. If I put up insulation do I need a vapor barrier? Or can I install some of the pink foam board type insulation and not use a vapor barrier? I've read arguements going both ways, some say I need it, some say I don't. Any help would be wonderful. |
I'd say yes. I've built for 30 years and am still unsure. All basements have different levels of moisture penetration. I don't think it can hurt in any case. I've been just using that 1mil painters plastic. It is cheap and goes up quick. Good luck.
I hung out at Hastings College in 1971. I love Nebraska and the people that live there. |
If you stud the wall out it might be best to install batt-type insulation in the cavities, then install an air/vapor barrier.
If you do use the the batt-type insulation:
....and you install the kind that already has a paper vapor barrier (i.e.- Paper faced), do not install an additional vapor barrier. Also, make sure that the vapor barrier faces towards the warm side (living space). |
If I go with the foam board type insulation will I need a vapor barrier?
Yes, Even if you use the foam board, you should have a vapor barrier. Same application as with batt insulation...facing the warm side.
Thanks, I'll get the hang of this basement finishing thing yet!
| All times are GMT -4. The time now is 04:58 PM. |
