Monolithic Pour - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-04-2009, 12:24 PM   #1
Monolithic Pour
I'm doing to do a monolithic pour on my garage addition and will need about 13 yards of concrete which will require two loads. Can I have my first truck deliver 3000 psi which will fill the footing and lower wall areas and then have my second truck deliver 4000 psi for the slab? The second pour would be put on top of the first pour right away (one truck would be right behind the other).
Jim Hart is offline   Reply With Quote
Old 06-04-2009, 01:13 PM   #2
Old School
Willie T's Avatar
For cryin' out loud. What is your price difference? I think it's almost nothing here. And I'm serious... a few bucks.
Willie T
Old 06-04-2009, 03:27 PM   #3
Rewards Points: 95
My first thought too.
NJ Brickie is offline   Reply With Quote
Old 06-04-2009, 11:29 PM   #4
Concrete & Masonry
Rewards Points: 620
My first thought, x3!
jomama45 is offline   Reply With Quote
Old 06-05-2009, 05:13 AM   #5
make it 4 then i thought - hhhmmmmmmmmmmmmm, he may be onto something so here's my suggestion - order up the 3,000 @ 7" slump w/wtr reducer, retarder, 2% calcium, & just a slight taste of super-p,,, that way you'll not waste a lot of time pulling the mud for the footing OR vibrating, it'll delay the set so there won't be any cold jnt/delamination, & less footing labor but you'll still gain hi early strength
the 2nd load can be 4,000 @ 3" or 4" slump,,, the only caution i can forsee is not using vertical supporting bars to prevent the top from sinking down into the bottom
IF you're not an experienced conc guy, you might consider you ARE already a cheapskate out-of-the-box thinker,,, pay the addl $$$ & do it like a pro - that also means bringing coolers & your favorite adult beverages
in theory, there's no difference 'tween theory & practice,,, in practice, there is ! ! !
in
yesitsconcrete is offline   Reply With Quote
Footer size for a monolithic patio that can support simple roof seth Building & Construction 2 05-19-2009 09:19 PM
Question on Monolithic slab - Pour all at once? seth Building & Construction 15 05-06-2009 03:36 PM
question on suitability of monolithic slab rtoni Building & Construction 5 03-31-2009 05:18 PM
Need to pour a footer Lawnworks Building & Construction 1 10-01-2008 06:43 AM
Driveway Pour Before the Rain.... Hages Building & Construction 1 04-18-2007 06:53 AM
