Moldy Sheetrock New Home Construction - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-03-2012, 05:53 PM   #1
Moldy sheetrock new home construction
New home construction elevated slab, full brick kitchen flooring installed 1 week ago & AC is not yet turned on. I live in New Orleans & today 1 week post Isaac noted that the sheetrock in the kitchen is wet & moldy. Did moisture from the brick wick up the sheetrock??? Thoughts anyone?
Eyeneedhelp is offline   Reply With Quote
Old 09-03-2012, 06:11 PM   #2
Rewards Points: 13,300
All that rain and no A/C running, no dehumidifer, high humidity, wet concrete drying out, drywall mud drying out, not a good mix.
Was the drywall installed about 1/2" up off the floor?
Can you post a picture of how bad it is?
Eyeneedhelp (09-03-2012)
Old 09-03-2012, 07:32 PM   #3
Wall's were insulated to the brick floor, we already gutted the walls 2feet
Old 09-03-2012, 08:36 PM   #4
Drywall extended to the slab, such that the drywall was between the brick/mortor and bottom plate. Yes, bad idea, as u say, drywall should have stopped half inch above the brick.
Old 09-03-2012, 09:49 PM   #5
Registered User
Rewards Points: 5,266
The mortar water (atomized) went to the walls, first condensing surface; http://www.buildingscience.com/docum...bout-diffusion
Were windows open for cross ventilation, mechanical fans? Clean it all before HVAC it all over the house...
Gary
Planning on painting interior of new construction home ~2500sq ft kehi66 Painting 13 06-10-2012 10:53 AM
How can I purposely lower the value of a new construction build? Two-Hatchet General DIY Discussions 31 05-01-2012 03:43 PM
A Southern Illinois Realtor ready to LEARN more about home construction and repair!! RealtorCasie Introductions 3 05-27-2011 09:56 PM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 03:41 PM
do it yourself home construction toby72 Building & Construction 4 06-20-2006 12:32 PM
