Mold Under Floating Wood Floor - With Photos - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-06-2012, 11:43 AM   #1
Rewards Points: 18
Mold under floating wood floor - with photos
Hello,
About 2 1/2 weeks ago had water damage to our lower level, which had a floating wood floor over a concrete slab.
We have started to take up the wood and pad (it is unsalvageable, we are discarding it all), but there is fuzzy mold on both the bottom of the wood, and on the bottom of the pad as well (white/green/creme colored mold, as well as darker mold on the wood).
My question is, is there a safe way I can remove this myself, or do I need to contact a mold removal team to deal with this, like Servepro? We're look at probably 400sf.
I have attached some photos so you can see what the mold looks like. Thanks for any advice.
Mold under floating wood floor - with photos-imag0043-sml.jpg   Mold under floating wood floor - with photos-imag0039-sml.jpg
rumiat is offline   Reply With Quote
Old 06-07-2012, 12:31 AM   #2
Rewards Points: 1,092
Safe? Maybe, unless you are allergic to mold, which can cause your throat to swell and you to suffocate. Myself, and I don't recommend you or anyone else do this, I would ventilate like all living H (huge fans, lots of openings), get some QUALITY masks, spray lightly with 5-10% bleach and water, then take it out myself. Be slow, and be careful. I would not touch it dry. When done, I'd wash w/ soap and water, let dry, then dampen it w/ more bleach and ventilate for a long time. All that said... is the water perhaps coming from below, and your flood just happened to have you dig in and find it? It may be advisable to watch the floor for a while after you are done to see if water is wicking into it. Tape a 2' square piece of visqueen to the floor and see if it gets water under it; rough idea, anyway. A pro is sure the safest!
Old 06-07-2012, 01:17 AM   #3
Rewards Points: 626
First off find out were the water came from and how it got there and fix that! second don't panic were gloves and dust mask bleach water and toss out all the moldy junk.
Nailbags is offline   Reply With Quote
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 07:02 PM
Mold on roof sheathing!!! DIYMILF Roofing/Siding 10 08-14-2011 10:11 PM
leveling an installed floating wood floor woody2 Flooring 2 08-02-2010 10:41 PM
Wood furniture care/ Cleaning (I ?!#?!? up) bli182nk General DIY Discussions 0 05-22-2010 02:31 AM
Floating Wood Floors? dag Flooring 1 06-22-2006 10:40 PM
