Mold Resistant Drywall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-12-2010, 04:11 PM   #1
Rewards Points: 31
mold resistant drywall
is mold resistant drywall a must in basement walls? These are perimeter walls walls and not basement bathroom walls.
kupalino is offline   Reply With Quote
Old 01-12-2010, 05:07 PM   #2
Remodeling Contractor
not a requirement just a good idea
Old 01-13-2010, 07:50 AM   #3
Mold grows at 80% RH.
If you're going to keep the RH under 80%, then you won't have mold problems. If you're going to let it rise above 80% then you might.
pyper is offline   Reply With Quote
Old 01-14-2010, 08:53 PM   #4
Mold resistant drywall (purple board) is a great idea in a basement. Do it once & do it right.
Don't forget to use mold resistant mud in a 5 gallon bucket (the one from GP with the purple lid) or the quick dry type that is sold in the bag and you mix it up, otherwise you are wasting your time as mold will grow in regular mud (joint compound).
If you want to take it all the way use one on the new mold resistant tapes for doing your joints. Then you have a full mold resistant system.
The new mud in the 5 gallon bucket is fantastic. Sooo creamy none of those annoying pinholes etc. I liked it. Made taping a dream.
infoskr is offline   Reply With Quote
Old 01-15-2010, 07:41 AM   #5
Mold!! Let's kill it!
Rewards Points: 2,012
Common household mold grows at 60% RH or .6 water content, between 40 and 110 degrees F.
Old 01-15-2010, 08:52 AM   #6
Rewards Points: 31
thanks for the replies.
Do I need Fire Resistant Drywall for this new room? vseven Drywall & Plaster 6 12-19-2009 04:00 PM
Found mold in the drywall - now what? Rileyhouse Drywall & Plaster 7 03-08-2009 02:16 PM
water damage remove mold & repair or replace drywall homerepair1 Drywall & Plaster 2 02-22-2009 11:00 AM
Would installing Moisture Resistant Drywall Backwards hurt anything? cdcamaro9534 Drywall & Plaster 6 11-01-2008 07:20 AM
Mold on Green Drywall - how to remove? TotallyLostAlisha Drywall & Plaster 4 08-05-2008 07:47 AM
