MOLD Found On Wood Subfloor Under Fridge-HELP!!! - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Old 12-24-2012, 08:06 AM   #31
Mold!! Let's kill it!
Rewards Points: 2,012
Borax would be a good choice to scrub mold from a surface. Regular Borax would not be my choice for a good fungicide. I don't know if there would be enough borates in it to really do a good job. Boron compounds are used as a preventive treatment. Vineger will kill mold. The acetic acid is what does the job. It would be corrosive. I would not dilute it. It is not the fungicide of choice since there are other things present in vineger that complicate it's effectiveness.
Old 12-24-2012, 07:52 PM   #32
Rewards Points: 528
Thanks for the info.I wondered about them.Was looking for something to use on white vinyl fence that doesnt always get the sun it needs and tends to grow mold.Heard vinegar and borax leaves a bit of a shield siminar to those chemicals in big box stores like mircrobial blocker.I know nothing will stop it totally outside in open,but may help.
hidden1 is offline   Reply With Quote
Old 01-09-2013, 11:36 AM   #33
CRS
The best solution for any mold issue is to completely remove it. Any "quick fix" will simply either hid the problem or only remove the surface issue. However the remainder of the mold will still be in the material and continue to grow
CRS is offline   Reply With Quote
Old 01-09-2013, 10:39 PM   #34
Rewards Points: 150
Just bleach it and scrub it off, if it is on the outside. Consider doing that as an annual cleaning...
oodssoo is offline   Reply With Quote
Old 01-10-2013, 09:30 AM   #35
CRS
By using bleach you will just change the colour of the mold. it will not remove it. That is just a "quick fix" solution. It will not remove the root of the mold in the material and the mold will come back
Old 01-10-2013, 09:03 PM   #36
You've never really studied mold or done much remediation, have you?
Old 01-11-2013, 09:27 AM   #37
CRS
If its surface mold, any microbial disinfectants will remove it, but if the mold has grown for a long period and is in the substance of the material, the only way to remove it is by replacing the material
Old 01-11-2013, 12:08 PM   #38
I agree that mold that has thrived on an organic material will have sent mycellia into the material that cannot be reached by a fungicide, however, there are building components that cannot be easily replaced. If the material is in a place where removal and replacement is impossible, then the mold needs to be treated by cleaning, treating and sealing, with particular attention paid to eliminating the moisture to prevent re-establishment of the mnold colonies. To state that bleach will only change the color, is misleading. There are several effective fungicidal compounds. Phenols, quaternary ammonias and sodium hypochlorite among them.
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 10 03-25-2014 09:21 AM
Mold problem after unfinished house was closed in for the winter... lemonbltz Building & Construction 28 12-30-2011 08:52 PM
ICF vs. Wood Framed JackOfAllTrades Building & Construction 31 11-01-2011 04:14 PM
Concrobium or White Vinegar? eis61374 Remodeling 8 11-17-2008 07:56 AM
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 04:29 PM
