Moisture On Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-20-2008, 09:15 AM   #1
Post
Moisture on walls
I live in Michigan and since the temperature outside has started to get colder I have noticed that we are getting moisture on the inside where the ceiling and walls meet. I have noticed a couple of spots that are high up on some high walls (these walls are open to the attic above). We also are getting moisture on the windows as well. The windows are vinyl with insulated glass and are only about 2 years old. The house is wood frame construction built in 1991 and is fairly well insulated, fiberglass in the walls and blown in insulation in the ceiling with insulated walls in a finished basement. Any suggestions as to what may be causing this? Thanks, Chris
chrisr is offline   Reply With Quote
Old 01-20-2008, 09:37 AM   #2
Eibwen
Probably high humidity in the house. It will tend to condense on anything cold. Thats assuming the insulation is up to par and no obvious air leaks.
Dehumidifier will help or improve the air circulation with some ceiling fans etc should help.
Sammy is offline   Reply With Quote
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
Moisture in Concrete LBlack Flooring 9 10-31-2008 07:24 PM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 08:39 AM
help! my walls are troubled donnamarie General DIY Discussions 5 08-29-2007 12:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
