Moisture Through Brick Wall - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-12-2012, 02:02 PM   #16
concretemasonry's Avatar
Rewards Points: 2,608
Flat roofs (older) with "deferred" maintenance can be a problem. With a bonded brick wall and a partially cavity, water obviously runs down and the drainage shows up there. Brick, despite it permanence is not waterproof and that is why the good walls are brick cavity walls.
With a roof leak, the interior damage may show up much higher or could be anywhere the water finds a path.
Dick
concretemasonry is offline   Reply With Quote
Old 12-12-2012, 04:21 PM   #17
I was hoping it wasn't a roof leak. Since all of the moisture is apparent within 3' above the floor. If it was the roof I thought the entire wall would have shown damage.
Is this a safe assumption?
matthewd is offline   Reply With Quote
Old 12-12-2012, 06:14 PM   #18
Rewards Points: 2,516
you may need to start opening up that inside wall...where the damaged plaster is....to see if you can find where the water is originating,
hammerlane is offline   Reply With Quote
Tags
brick , masonry , moisture , rain , water
Brick Wall Fireplace Questions mjoe Remodeling 3 12-03-2012 07:40 AM
Attaching Willow Screen to brick wall tripled Landscaping & Lawn Care 5 08-12-2011 06:46 AM
DIY fireplace remodel gone awry - impenetrable brick wall shawnad73 Building & Construction 8 08-23-2010 08:52 AM
how to tell if a brick wall is load bearing eskowitz Building & Construction 10 08-01-2010 10:00 PM
Peplacing rotten framing against brick wall minnjh Carpentry 2 07-01-2009 03:21 PM
