Moisture And Stucco - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-07-2012, 06:48 PM   #1
moisture and stucco
i live in sc. moisture is a real problem, but i would like to build a raised flower bed against my house. it will be in contact with stucco. how can i do this without the moisture from the garden soil ruin the stucco?
april1 is offline   Reply With Quote
Old 08-07-2012, 07:01 PM   #2
Rewards Points: 13,732
I would forget that idea.
Not going to work that close to the ground.
april1 (08-08-2012)
Old 08-07-2012, 11:12 PM   #3
Registered User
Rewards Points: 5,516
Welcome, I'll move you to more answers...!
Gary
Old 08-08-2012, 12:04 AM   #4
robertcdf's Avatar
I'd also advise against it... However, if you insist use an elastomeric paint to paint the stucco to nearly waterproof it (stucco is not waterproof, it's a cement product that will leach water).
robertcdf is offline   Reply With Quote
Old 08-08-2012, 12:33 AM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 1,824
The 'rules' on stucco have changed a bit over the years.
What is on the backside of that stucco? If it is a framed wall...then you don't want anything against it.
However, if it's concrete foundation....no problem.....
With that said....in the old days, when they stucco'd a house, they did it all the way down to grade (dirt)
Now....you stucco down to the bottom plate....at that point you will have a weep screen..this lets any moisture that gets behind the stucco to go down the wall.
The Following User Says Thank You to ddawg16 For This Useful Post:
april1 (08-08-2012)
Stucco cracks and stucco questions FrankL Building & Construction 2 05-22-2011 06:23 AM
color streaks on new stucco homeowner in Minnesota Building & Construction 2 08-11-2008 07:07 PM
Stucco on interior cmu/fireplace andys Building & Construction 1 06-24-2007 03:02 PM
