Old 11-06-2009, 03:59 PM   #1
Angry Moisture Problems My basment
I Had Just Built a House Myself and Finished the House
Now I had a problem with the Slab in the basement - Moisture Wicking Up I Found no Vapor barrier Under Slab. I Highered Out the Slab work to a local Contractor to pour a slab - He Never Said Anything about a Vapor Barrier - so anyway I never knew anything about it till last winter after the rooms smelt Musty and the Carpet underlay was damp – So any ways this past Summer I Poured a new Slab on Top with a 6mill Polly In-between – I Lifted all the walls and Slid a 6 Mill Polly Under the Wall and Poured a 1.5 inch with Fiber Mesh New Slab On top on the existing and poured around the walls– the Problem Seems to be solved the humidity went from 70% to 50% in one week even with slab drying out. Did I do the right thing? I have big O around the House and Is Working - I have a sump Pit and the water table was down 3 feet delow the Slab also I did See 6 inches of gravel under the slab. Is this a Good Fix or…
EV-Dutchy is offline   Reply With Quote
Tags
basement humidity, concrete, moisture, problem, vapor barrier
More On This Topic
Hi this is Jon on behalf of Expert Village in this video clip I will show you how to remove your side trim boards. On this side we need to remove our gutter first before we can have access to our trim board. You need to unscrew where you gutter... Read More »
This is Ben Ingham with Expert Village talking about a walk out basement. The next step in the process was to have the slab poured in the base here and actually I have that as a term key job because it was about 20 yards of concrete and that is more then... Read More »
If you are planning a concrete project, you will be dedicating your time and money to making it perfect. Whether you will be doing the job on you own or hiring a contractor, there are a few things you should think about before getting started. While it... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. I want to talk to you a minute about these gaps that we are seeing on the bottom of this... Read More »
The presence of mold in the home can potentially have very dangerous consequences to your health, the health of your family and that of your pets. It is important that you locate dangerous mold in your home, remove it and dispose of it properly in order... Read More »
Moisture meters and radiant concrete slab snowydaysrock Plumbing 0 01-16-2009 08:00 PM
Moisture in Concrete LBlack Flooring 9 10-31-2008 09:24 PM
Are you having ice problems? Grumpy Roofing 28 08-25-2008 10:16 PM
Moisture problems when 'heating only when needed' in insulated garage? timg HVAC 10 01-18-2007 07:38 PM
Moisture and Mold Problems Vin Building & Construction 0 01-20-2005 10:25 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
