Moisture In My Washroom - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-24-2011, 11:43 PM   #1
Moisture in my washroom
Hi there,
I purchased a house in which the basement is made and the cold cellar is made into a washroom. There is proper ventilation going outside however there is constant moisture collecting on the floor tiles. There is no mould on the walls. What could be the problem?
Tazza is offline   Reply With Quote
Old 06-25-2011, 07:00 AM   #2
Cold floor, moist air, moisture condenses on the cold floor. You need to find a way to install a fan that exhausts outside.
The Following User Says Thank You to Just Bill For This Useful Post:
Tazza (06-27-2011)
Old 06-25-2011, 07:57 AM   #3
Rewards Points: 5,336
Dehumidifier and maybe some insulation and vapor barrier. It depends on the construction you have .
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
Tazza (06-27-2011)
Cleaning brush StevenH Painting 19 02-06-2011 12:13 AM
Basement Moisture, what's this? bergerdude Building & Construction 1 06-11-2010 02:27 PM
Moisture meters and radiant concrete slab snowydaysrock Flooring 7 01-21-2009 07:33 AM
Moisture mystery in midst of shower redo Hisgirl Remodeling 3 01-05-2009 10:29 AM
