Moisture Issues - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-23-2010, 12:08 PM   #1
Moisture issues
Recently my garage was closed in and converted to a living room. The concrete floor of the garage was 21" below the finish floor of the house. The contractor sealed off the crawl space, he said "it was to keep the critters out". I live down south where humidity is always high and feel that there will become a moisture problem.
The contractor used const. Adhesive, cont. Metal flashing and shot down a treated 2x6, the flashing wraps upward to the sill to create a closed seal.
Will this become a problem or am i ok
CUYON81 is offline   Reply With Quote
Old 09-23-2010, 02:51 PM   #2
Are you talking about the space beneath the new room (old garage), or your crawl space for the entire house? Pictures would be a big help.
littlecleo is offline   Reply With Quote
Basement Moisture, what's this? bergerdude Building & Construction 1 06-11-2010 01:27 PM
Basement Bathroom - Sheetrock - Moisture Issues. mikeynpz Building & Construction 2 05-24-2009 10:08 AM
Moisture meters and radiant concrete slab snowydaysrock Flooring 7 01-21-2009 06:33 AM
Moisture mystery in midst of shower redo Hisgirl Remodeling 3 01-05-2009 09:29 AM
basement issues - tile, mastic, moisture pfisch Flooring 6 12-01-2008 01:35 PM
