Moisture Inside Large Windows - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-13-2011, 11:12 AM   #1
Moisture inside large windows
I have significant moisture buildup inside my large dual pane windows. It has been getting worse this winter to the point where I can see water drops running down the windows between the two panes. These windows say IGMAC PPG TWINDOW CALGARY 1988 on them. I will try to contact this company in Calgary (300km south of me), but I thought I would get some advice here first.
Thanks so much
mibson is offline   Reply With Quote
Old 02-13-2011, 11:41 AM   #2
Tom Struble's Avatar
Rewards Points: 2,002
is that a Lindal home?
while it,s unsightly and means the seal has failed,it doesn't necessarily mean the window is significantly less efficient then when they were new,
there is a technique to remove this moisture
"Defogging" double-pane windows .... a gimmick??
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
mibson (02-13-2011)
Old 02-13-2011, 11:49 AM   #3
Im not concerned about the window efficiency but just the amount of moisture almost seems enough that it could be leaking out and damaging wood somewhere?
I think it is a Lyndal home. The previous owners said it was.
Old 02-13-2011, 12:08 PM   #4
you are right,that could possibly be happening
Old 02-13-2011, 12:18 PM   #5
Yes, my concern is damage to any part of the house from moisture. I dont like the look of the moisture in the windows but I wont be replacing these windows without winning the lottery and the defogging methods just dont make sense to me as a long term solution.
This is not just some fog in the window, I can actually see 10-20 dropplets of water that accumualte and run down the inside of the window to the bottom seal.
For now, I just want to figure out if moisture is running out of the window seal down into the structure of the house causing damage.
Old 02-13-2011, 01:25 PM   #6
i believe Lindal uses an outside weep system on those fixed units,there may be a removable stop that can be pried up for a closer inspection,there may even be an actual owners manual for the care and upkeep of your home and what finishes are recommended
Your home is built with beautiful western red cedar and should be protected with the recommended materials and maintained as the factory recommended
you should contact Lindal there may even be a warranty program,or at the least they can give you the guidance you need to properly maintain your home
http://lindal.com/homes/techcenter/
Basement moisture - why not seal inside wall? BRO931 Building & Construction 10 08-30-2010 01:47 PM
Basement Moisture, what's this? bergerdude Building & Construction 1 06-11-2010 01:27 PM
Typical Cost to Install Anderson 400 Windows jombres General DIY Discussions 1 10-16-2009 09:57 PM
New Windows installed over old windows Lakehome Remodeling 1 03-14-2009 01:39 PM
Adding large windows and a door to existing wall cpused Remodeling 7 02-23-2008 10:07 AM
