Moisture Barriers In Elevated Homes - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-09-2011, 11:35 AM   #1
Moisture Barriers in Elevated Homes
We have a home which was elevated after a hurricane and flooding.
We are now 11.2 feet above ground, but local codes demand that we put a moisture barrier down. We have two levels of flood vents and 3x 4 opening on each end of the cinder block foundation.
We are required by flood insurance to keep vents and flood doors open at all times. What is the point of putting down plastic, etc at this point.
ckip is offline   Reply With Quote
Old 11-09-2011, 09:26 PM   #2
Rewards Points: 1,092
"What is the point of putting down plastic, etc at this point." It sounds like the only reason is to comply w/ a code that does not apply to you. Ain't gov't just great? Put down the visqueen and call it good.
Old 11-11-2011, 09:05 PM   #3
Registered User
Rewards Points: 5,514
http://www.buildingscience.com/docum...n-crawlspaces/
Gary
Cleaning brush StevenH Painting 19 02-05-2011 11:13 PM
Basement Moisture, what's this? bergerdude Building & Construction 1 06-11-2010 01:27 PM
Moisture meters and radiant concrete slab snowydaysrock Flooring 7 01-21-2009 06:33 AM
No Moisture Barriers 1parkpointer Roofing/Siding 4 12-11-2008 06:44 PM
