Old 10-03-2012, 10:14 PM   #1
moisture barrier question in crawlspace
In our crawl space there's a plastic moisture barrier then stone on top. Is that the right way to do it. We were informed it should be the opposite. Stone then plastic?
Peggy Kapral is offline   Reply With Quote
Old 10-03-2012, 10:35 PM   #2
Is just putting plastic moisture barrier enough? Can stone go on top of the plastic in a crawl space?
Old 10-03-2012, 11:16 PM   #3
i have seen it both ways. some say put some crushed limestone on top give the crawlspace a sweet smell. i personally do not like gravel in crawl at all due to more likely to puncture the moisture barrier
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
jaydevries is offline   Reply With Quote
Old 10-04-2012, 08:41 AM   #4
Stone serves no purpose under or on top of the plastic. Just using 16" insulation hangers bent in half will hold it in place.
Peggy Kapral (10-04-2012)
Crawlspace Vapor Barrier cbaur88 Insulation 6 12-17-2011 10:31 PM
Vapor Barrier retrofit question bicycle-rider General Discussion 3 02-05-2011 01:29 AM
Moisture barrier for framing pennshaq Remodeling 0 07-02-2010 08:45 AM
Moisture Barrier and Adhesive Removal joe_cole5000 Flooring 5 01-31-2010 04:06 PM
Rigid insulation/vapour barrier in crawlspace shtoink Building & Construction 2 10-10-2009 12:00 AM
