Moisture barrier installation question for replacement siding
Do I need to strip all trim and corner boards so that I can wrap the home with a continuous layer of moisture barrier?-------- YES! The corners are a very weak link: 1. The starting and ending place for most applications (the barrier is seldom folded up 5 times to maintain a waterproof joint there). 2. The corner boards are usually wood that opens and closes joints with season changes. The caulking /siding/trim joint opens and fails there (looks good from the surface).
"Also, I have what appears to be some type of asphalt (black) sheathing behind my siding (not plywood), should I still use a house wrap with this or will it block off the breathabilty?" --- probably 30 or 15# asphalt paper (the real deal unlike today's 15# that weighs 7-1/2#). Read my other answer to breatability issues.
You spent a lot of money and research on the job, yet leave corners on......
Be safe, Gary
Clothes taking longer to dry?
