Moisture Barrier - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-06-2011, 10:03 PM   #1
Moisture barrier
hi i recently bought a house with a tarmac floor the room should have floating timber floor with vents but some dope decided to install tarmac "the smell is awfull i have removed the floor and am down to dirt i was going to install a concrete floor then build walls on it and then timbers on the walls .
my question is should i use a moisture barrier under the concrete slab i vapour barrier concidering it is between the walls and the moisture would have nowhere to go or should i just pour concrete and let the moisture come through concrete and then get carried away by air vents under timber floor thanks.
dubbud is offline   Reply With Quote
Old 07-07-2011, 12:50 AM   #2
AGWhitehouse's Avatar
Moisture barrier
Put a 6 mil minimum vapor barrier beneath the concrete slab.
AGWhitehouse is offline   Reply With Quote
Cleaning brush StevenH Painting 19 02-06-2011 12:13 AM
how important is it for moisture barrier to cover sides of floating floor? conradA Flooring 2 04-29-2010 11:13 AM
Moisture Barrier for Partially Below Grade Grouted CMU Wall Fire4Effect Building & Construction 4 07-06-2009 12:51 PM
To Moisture Barrier or Not to Moisture Barrier? cordon Flooring 7 05-22-2007 10:48 PM
moisture barrier - help! jediracer Carpentry 12 10-03-2006 07:32 PM
