Moister Behind Vapor Barrier - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-24-2008, 08:43 PM   #1
Exclamation
moister behind vapor barrier
We are remodeling, and we took out the insulation to put in wiring, now since we've put the insulation back we noticed moisture behind it. Is that normal, because the drywall is not up yet?
tomandkimmoore is offline   Reply With Quote
Old 01-25-2008, 06:49 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 650
Ayuh,.....
My Guess is,.....
When you removed the drywall,+ insulation,.... The outer wall becomes boarder between the Warm inside air,+ the Cold outside air,.....
Hence,..... Condensation is forming on That surface......
