-   -   moister behind vapor barrier (http://www.diychatroom.com/f19/moister-behind-vapor-barrier-16098/)
tomandkimmoore 01-24-2008 07:43 PM
We are remodeling, and we took out the insulation to put in wiring, now since we've put the insulation back we noticed moisture behind it. Is that normal, because the drywall is not up yet?
Bondo 01-25-2008 05:49 AM
Ayuh,.....
My Guess is,.....
When you removed the drywall,+ insulation,.... The outer wall becomes boarder between the Warm inside air,+ the Cold outside air,.....
Hence,..... Condensation is forming on That surface......
