Moist Soil Under Raised Foundation During Winter - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-17-2010, 03:51 AM   #1
moist soil under raised foundation during winter
I have a house built in the mid 70s on a raised foundation. During the rainy season I have found that the soil under the house is quite moist. The house in built on a hill with a rise of about 3 feet x 20 feet run. I have garden steps, brick over sand, that run down the side of the house to the lower level. Soil is back filled next to the foundation. During rains a lot of water flows down the steps and side of the house from my driveway. I believe this is the main cause of the water pressure pushing under the foundation.
Question, can this be fixed by pouring a concrete trough as a drain and slab steps next to the foundation, using a asphalt fiberboard spacer between the foundation and the cement trough. The water would be directed to a drain at the lower level. On the other side of the concrete steps I would placing a French drain. Would a french drain be needed next to the foundation as well or could that cause foundation damage?
What would be a better solution?
Tx,
Brent
bn300 is offline   Reply With Quote
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 07:50 PM
Concrete Foundation in Winter... Very worried!!! ChathamJedi Building & Construction 12 01-11-2010 06:12 PM
What to do about bowing and moist foundation walls 99miles Building & Construction 7 09-26-2009 08:39 AM
Grading Soil during Chicago WInter stefonroman Landscaping & Lawn Care 6 03-01-2009 11:55 PM
Foundation work in winter? Rexkwondo Building & Construction 4 12-11-2007 05:28 PM
