Old 12-28-2012, 11:59 PM   #1
Post
Modular home - marriage wall
I am planning on a project that will involve removing the plywood between several studs on the marriage wall. Can anyone tell me if this will create a detrimental loss of strength? This is a 1-story house with a ~4' attic with plywood. I will be removing 6 x 5' sections from in between the studs.
Any advice will be appreciated.
tlowe65 is offline   Reply With Quote
Old 12-29-2012, 08:51 AM   #2
Yeah, don't remove nothing Modular homes are very precisely engineered homes.
Contact the Factory that built the home or take the plans to an Engineer or Modular home Company and ask the questions.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
The Following User Says Thank You to COLDIRON For This Useful Post:
mae-ling (12-29-2012)
Old 12-29-2012, 09:11 AM   #3
Good advice, please take it.
When you say it's only a 4' tall attic ( I believe that's what you meant) that sounds more to me like a mobile home not a true moduler.
The clue is low pitch of the roof so it can be driven down the road.
If there's a steel frame under it, or it came on wheels it's not a true moduler.
Differance is there built very differant.
Old 12-29-2012, 11:09 AM   #4
I live in a "Real Modular" the attic space is only about 4' or 5' high.
When it's shipped the roof is collapsed because it is hinged and is lifted when the home is in place. Once it's in place you'd never know if my house is stick built or factory built.
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 01:26 PM
Core filling a bowing wall, please assist silverstrike Building & Construction 12 06-16-2012 11:28 PM
Residential air handler in modular home. Doc Holliday HVAC 31 04-23-2012 09:11 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
modular home flooring problem wen Flooring 1 08-15-2005 02:11 PM
