Modifying Existing (old) Framing To Extend Stair Opening - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-27-2013, 12:17 PM   #1
Modifying existing (old) framing to extend stair opening
I have a 100 year old home with a very low clearance (< 6 ft) above the stairs between the first and second floor. Moving furniture (or being tall) is really difficult in our home! Since I'm working on a reno on the second floor and have the floor joists exposed anyway, I thought I might take a stab at fixing the problem.
I've attached a couple of drawings showing the existing structure, and two options I've come up with for extending the stair opening by one joist bay. The second option is a little "cleaner", but it would involve more plaster repair. In both options I'm not sure what to do with the end of the new sistered joist where it meets the double brick wall. I'm hoping I can get away without cutting a new pocket into the brick, but I'll do it if I have to.
You are not my engineer, I know. I still want to hear from anyone who might have done something like this before to see what option looks the most sensible.
nuclearnerd is offline   Reply With Quote
Old 05-27-2013, 12:29 PM   #2
Here's a pdf copy of the drawings
Old 05-27-2013, 05:52 PM   #3
DIY staff
Rewards Points: 7,174
The second drawing is the safest--the last one uses scabs to hold the outside joist and ,while workable. is not as good as the one above ----
Old 05-28-2013, 10:53 AM   #4
Thanks Oh'mike. The third drawing actually uses the stud below to support the extended header. The "scab" plates are just to keep the splice in-line. That said, the second drawing is easier to make anyway.
In both cases I'm relying on the stair wall below to take the vertical load from the splice in the header. I'm having a tough time convincing myself though, because the current building code prevents studs "on the flat" from being used as a structural wall (although that clearly wasn't the case in 1920).
Old 05-28-2013, 01:52 PM   #5
Bill Kearney
Rewards Points: 1,174
Yes, that might be an issue for getting it permitted. But since you're going to be tearing up a fair bit of wall around the area that shouldn't be too much trouble to just frame it up to current code requirements.
wkearney99 is offline   Reply With Quote
Old 06-24-2013, 12:10 AM   #6
Just as a follow up: I took wkearney99's advise. I reframed the wall below to extend it one more stud. Now the joist that I'll cut is supported from below, and I don't have to stress too much about sistering joists above. Thanks for all your help.
Tags
brick , framing , renovation , stairwell , structural
Best way to flatten/level existing ceiling framing? RolandOG Building & Construction 20 10-13-2008 06:28 PM
Framing a partition wall on existing carpet and ceiling tile? eagle86 Building & Construction 3 07-23-2008 03:39 PM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 03:44 PM
Modifying existing duct work Thurgee HVAC 3 04-05-2007 09:35 AM
Framing Opening Length captainron19 Carpentry 3 04-01-2006 10:50 AM
