Mobile Home Crawl Space - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-29-2010, 04:47 PM   #1
mobile home crawl space
I was told that you can use 2" polyethylene for insulating under a
mobile home .
i know that it is used for pipe insulation but not sure about this .
any advise on this matter would be a appreciated.
the material is 2"x48"x96".
thanks cal.
Cal. is offline   Reply With Quote
Old 10-30-2010, 11:55 AM   #2
Rewards Points: 292
Here is a link on conditioned crawl spaces. http://www.buildingscience.com/docum...ance-and-codes If you are talking about adding 2" foam, I'd assume the mobile home no longer has an intact belly board. You will want to seal in the foam somehow to keep out drafts and vapor. Great Stuff might work. Complete and properly vented skirting is important to conditioning the crawlspace under a mobile home as well. Exposed supply pipes should be wrapped with heat cable (not tape) and insulation.
Jim F is offline   Reply With Quote
Crawl space gas leak WillK Plumbing 13 10-19-2010 09:58 AM
Please help! on painting mobile home walls LilDarlin Painting 11 08-17-2009 05:04 AM
Crawl Space Beam and Joist Support Questions Fire4Effect Building & Construction 5 06-28-2009 01:07 PM
Insulating crawl space jenoble99 Building & Construction 10 06-18-2009 12:09 PM
crawl space and moisture Jeremy Hillary Boob, PhD Building & Construction 5 11-27-2008 08:13 PM
