Old 11-09-2004, 04:06 PM   #1
mmmmm ceilings do i or dont i
help !!! i am about to rip out the ceilings in our new home but as i am skint i need to know if i can tape and joint a ceiling ?????????
i know wall boards are tapered but only on two sides ,,,im just trying to save on skimming :o
spratster is offline   Reply With Quote
Old 11-09-2004, 09:13 PM   #2
You tape and spackle ceiling joints the same as you would wall joints. It's actually easier to hide joints in corners then it is on flat wall. Just lay your spackle thin on the tape so you have less sanding to do later. I don't know which tape you're using. I prefer the fiberglass mesh tape over paper tape. You don't have to spackle an undercoat before the tape. And the mesh tape is self stick also. You don't have to worry about the tape becoming bubbled up over time cause of air pockets like it always seems to do in some areas.
Hammertime is offline   Reply With Quote
Texture coming off of ceilings mrswoodward General Discussion 7 08-16-2007 08:42 AM
8 foot ceilings -- tray ceiling? lordlang General Discussion 1 12-29-2006 07:09 PM
Vaulting my 8 ft Ceilings ALL CITY Remodeling 2 11-01-2006 05:33 AM
Raising The Ceilings propain Building & Construction 2 06-28-2006 06:33 PM
Spray painting popcorn ceilings Bill M Painting 3 01-26-2006 04:11 PM
