Mixture Of Siding Material (Vinyl And Wood) - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-17-2011, 12:10 PM   #1
Mixture of Siding Material (Vinyl and Wood)
Hey Everyone,
I am working on an old house. It is 2.5 stories with 3 dormers. The dormers are difficult to reach as the roof is steep and short - I am guessing I will need a lift to work on them from the outside. My question is in regards to the siding. Right now the house is sided with cedar lap siding with a 2.5 - 3 inch reveal. Most of the siding is in good shape. The dormers however need some work. Next year I would like to replace the cedar siding on the dormers with vinyl but leave the rest of the house in wood. I don't particularly care for vinyl, but no other material has a reveal this size and I woldn't have to paint that area (except for the window trim which I can do from the inside) which would be a big plus.
Has anyone done anything like this? Part of the house in wood and a non-adjacent area in matched vinyl? Am I out of my mind here? Will this look bad in 5 to 10 years? I am just trying to set myself for less maintenance with the dormers due to their inaccessibility.
Thanks,
John
jburr827 is offline   Reply With Quote
Old 05-17-2011, 12:34 PM   #2
Rewards Points: 2,240
The dormers are 2.5 stories up.
That far up no one is going to notice the siding on the dormers -
That far up you don't want to paint -
The siding on the dormers will not match - even close.
Side the dormers with whatever siding you choose -
(Don't want to paint/stain - then: vinyl)
Just find something you like (vinyl).
Yes, we've done the same thing -
cedar siding (deteriorated), with the rest of the house in Cedar, brick,
aluminum, cement board, etc...)
It would have been nice to put up new Cedar; except, for money
constraints.
So, it was vinyl.
It looks alright.
rossfingal
Also, before you side it (with whatever you're going to side it with - check the "flashing" on the
dormers).
rossfingal is offline   Reply With Quote
Old 05-19-2011, 08:38 AM   #3
Thanks for the response - I'll probbaly move in that direction. Might stick with wood for the dormer that faces the road and do a vinyl gingerbread on the other two. or something like that.
John
Tags
dormer , siding , vinyl , wood
Replacing wood siding with vinyl jbjones Building & Construction 33 05-02-2011 12:23 AM
Vinyl siding over wood travem Remodeling 6 02-06-2011 10:32 PM
New Vinyl Siding Went From $43k to $15k In A Few Days nycgto Off Topic 12 07-26-2010 11:46 PM
vinyl siding over wood siding loyal Building & Construction 6 05-26-2009 12:17 AM
Replacing Wood Siding WIth Foam Backed Vinyl xludan Building & Construction 1 05-21-2009 06:27 PM
