Mixing Portland - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-01-2010, 09:05 PM   #1
Carpenter
Mixing Portland
Well I'm building a 16x22 shed built on piers. I'm mixing the concrete using 3, 2, 1, method...I can't get a straight answer from anyone on what kind of "gravel" to use. The package says use gravel not stone. Everyone looks at me crazy when I tell the this. to me gravel is like the 3/4" road gravel with the sand mixed in, where I look at stone is clear washed stone. Any advise???? Thx Fred
Bucky Badger is offline   Reply With Quote
Old 10-01-2010, 09:34 PM   #2
Concrete & Masonry
Rewards Points: 470
I understand your confusion. Typically around here, "gravel" draws the assumption of a mix of stone and fines together. That's at least what I think of for gravel. But, that's definately not what you want here. Road gravel makes a great base, but contains too much "dirty" contaminents like clay, soil, etc... to be used in concrete.
What you need is #1 washed stone (pea stone if pouring thin) and torpedo sand, which is washed as well.
jomama45 is offline   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
Bucky Badger (10-02-2010)
Old 10-01-2010, 09:57 PM   #3
Civil Engineer
Rewards Points: 4,522
Jomama is quite correct. All concrete is mixed using four fundamental ingredients, namely cement (typically Portland cement Type 2), sand, aggregate (what you are referring to as gravel), and water. The typical ratio is one part cement, two parts sand, and three parts aggregate, by volume, with the proper amount of water added to make the mix placeable, but the least amount necessary. The actual ratio can be varied depending on the required strength, and whether you are using a plasticizing agent.
Gravel is a badly defined term that means many different things to different people, and should not be used to describe aggregate in concrete. To a geotechnical engineer, gravel refers to a minimum particle size, typically about 1/4 inch in diameter or larger. However, as noted by others, gravel can mean a mix of materials to some people, bank run material to others, or it may not mean anything at all.
Why the package would tell you to use gravel not stone is beyond me. Typically around MA the aggregate is anywhere from 1/2 inch to 1 inch diameter crushed stone, washed to remove fines. You don't want any silt, clay or organic material in concrete. You can use almost any type of crushed stone, example limestone, sandstone, granite, even hard shale pieces in concrete, as long as it is clean and appropriately sized. And the more angular the better, round stone makes for a weaker concrete.
Daniel Holzman is online now   Reply With Quote
The Following User Says Thank You to Daniel Holzman For This Useful Post:
Old 10-02-2010, 09:18 AM   #4
Carpenter
Thanks guys..that's what I thought. I usually buy "all in one bags" but with a big project I thought i'd mix it myself
Jomama45, where you at in WI?
Can Portland Cement Be used instead of Floor Leveler? jonathan03 Flooring 9 07-23-2010 12:21 AM
Lime, type S/N cement and portland zantar Building & Construction 8 07-11-2010 09:53 PM
Help w/ mixing valve (I think) ink HVAC 15 02-28-2010 11:01 PM
general question on portland cement rtoni Building & Construction 2 07-11-2009 09:32 AM
clumps in hot mudd - hand mixing newbpainter General DIY Discussions 11 05-17-2009 07:21 PM
