Missing Roof Rafter (any Reason?) - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-11-2010, 12:38 PM   #1
Missing roof rafter (any reason?)
Hi guys,
In the process of adding a ceiling/collar ties to the room we're redoing (with dormers), I found that the builders of the house skipped a rafter. I went into the attic to see if there were any reason why, but I didn't find any. The only thing I can think of is, they spliced the ridge beam in that area, and perhaps they intended on putting some sort of plate or board over the the area, but never did. They put the rafter, though, (16 OC) on the other side of the ridge in the same area.
Anyway, I needed to add the collar ties up, and the rafter was a pretty easy cut (square on the bottom), so I just threw it up there. Would there be any good reason they would have left out this rafter?
I'm just wondering, since this happens to be the area where there is a ridge splice.
Joe
Joe1. is offline   Reply With Quote
Old 09-11-2010, 05:23 PM   #2
Registered User
Rewards Points: 5,216
Nope, and you don't need a ridge board splice plate. Code allows opposite rafters to be gusseted at the ridge without a ridge board. It is not required to scab over a butt joint or break the board joint on a rafter. (Non-structural ridge). This should cause a stir.... http://www.finehomebuilding.com/how-...llar-ties.aspx
Always build to your local Code.
Gary
Old 09-11-2010, 11:01 PM   #3
Okay good. Yeah, these framers did a lot of things strangely on this house, but I just wanted to ask in case there was an explanation. But I mean there were 16 OC X's on the ridge where they intended on putting the rafter....Maybe they ran out of wood.
Joe
Flat roof and insulation quandry paredown Roofing/Siding 2 08-21-2010 12:50 AM
EPDM Roof Plans stubits Roofing/Siding 44 05-01-2010 12:06 AM
Extend House Roof Over Back Deck Justahome Carpentry 1 04-03-2009 08:25 PM
Missing shingles on roof dankreboot Roofing/Siding 3 03-23-2009 07:04 AM
Tile+Asphalt Roll Roof leaking - Opinion on what to do brookbphx Roofing/Siding 5 01-06-2009 07:51 AM
