Misc. Building Questions - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-10-2011, 12:25 PM   #1
1. When laying out the dimensions to rooms in a house, what is the proper way to measure? Basically, if I say I want Room A to be 12'x12", is that from stud to stud, or sheetrock to sheetrock? Also, how much do you add for sheetrock and stud when laying out a room on the other side of the wall?
2. Foundation walls first, then concrete floor for basements? Also, when do you put in pipes, sewer, ect? Before foundation is layed? Or after foundation walls are poured?
I am wanting to learn more about the process into designing a house. I'm no architect, so I am just wanting a better understanding of everything. One day, maybe, I hope to oversee the building of my own house.
ws450r is offline   Reply With Quote
Old 02-10-2011, 03:01 PM   #2
Regarding room measurements, I've seen either system (centers of walls and paint to paint).
The important thing is to make sure whoever puts them in knows what you've done.
Unless you're there when they do it, they might not measure all that carefully, anyway. Depends on the crew. One thing that seems universal though -- if there's any question, they won't wait for an answer.
I like doing initial sketches on graph paper -- 1 foot to a quarter inch square, using a half a square for a wall thickness.
pyper is offline   Reply With Quote
Old 02-10-2011, 04:35 PM   #3
Registered User
Rewards Points: 4,936
Use some notes injected in the technical jargon to protect your drawings (liability), find “Waldo”; http://www.habitatcaz.org/constructi.../08-%20GSN.pdf
Click on the “Preview” just below each book title; http://www.google.com/search?tbs=bkv...G=Search+Books
Gary
Adding a subpanel to a sub-panel and other questions CardinalPilot Electrical 14 03-30-2011 03:23 PM
Equipment shed questions downunder Building & Construction 0 12-24-2010 11:08 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
A few questions about building a wooden privacy fence in Florida Tineras Building & Construction 4 03-22-2009 02:38 PM
Questions on Building apartment On top of existing detached garage nsxman2001 Building & Construction 4 12-16-2008 05:36 PM
