Old 03-22-2007, 04:13 PM   #1
mt232's Avatar
minimum window height
is there a minimum height requirement for the sill of a non-egress bedroom window (for child safety, for example?)
thanks!
mt232 is offline   Reply With Quote
Old 03-22-2007, 07:01 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
thanks!
I believe it is 18" from the floor height to the actual glass...
....If there is glass below that height, it must be tempered.
- Build Well -
Old 03-22-2007, 09:37 PM   #3
remodeling pro
Unless the code has been recently updated, anything within 20" of the floor has to be tempered, but there is no minimum sill height requirement above the floor, the window can go all the way to the floor. I believe there are rules about this for upper story windows though, in that they need a barrier to keep children from being able to climb or fall out the opening. I'd go with a call to the local building dept. on this one.
troubleseeker is offline   Reply With Quote
Old 03-22-2007, 09:58 PM   #4
This may be relevant to area/region codes, but....
You might want to check this info (codes) out again.
We just went thru this with Pella and an addition with untempered glass below 18".....(December '06) and we were working with an architect on it...
- Build Well -
Old 03-23-2007, 06:03 AM   #5
General Contractor
joasis's Avatar
I can't lay my hands on my code book, and I don't think I have ever even had to consider that one...we have done a lot of 3/0-5/0 windows....there is a maximum heights from the floor of 42 inches for an egress window, but that was all my quck code check showed.....
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Old 03-23-2007, 08:36 AM   #6
mt232's Avatar
Thank you all. I won't be coming anywhere close to that. Seeing my 3 year old near a proposed window height, i thought, or even hoped, it would have existed and been closer to 3 feet.
Old 03-23-2007, 09:53 PM   #7
remodeling pro
That's my line about going with a call to the local building dept. As all of us in this business know, the national codes are not accepted carte blanche, so when building in Rome, you have to do what the Romans do
Old 03-24-2007, 02:10 AM   #8
...what do the romans do?
- Build Well -
Shrink Film Window Insulation miserlou General Discussion 10 11-24-2008 07:19 AM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 05:49 AM
Double hung window trim helpless handyman Carpentry 24 04-10-2007 09:49 PM
I blew it on the mesurements.Vinyl window Doug Crf Remodeling 6 03-29-2007 11:06 PM
locate a vendor for vinyl window pane trim bjr23 Remodeling 1 02-14-2005 12:59 AM
