Minimum Size Door For Bathroom? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-04-2010, 02:10 PM   #1
the Musigician
DangerMouse's Avatar
Minimum size door for bathroom?
Is there a minimum size door for a bathroom with one door in/out?
I would imagine there is, and anything 30" to 36" or beyond is OK?
Thanks guys!
DM
Old 08-04-2010, 10:19 PM   #2
Rewards Points: 1,092
Standard interior doors are 30". If you are planning on living there till death do you part, or maybe getting hit by a truck before then, if you can, use a 36". I believe wheel chairs can get through a 36" door OK. GL. j
Old 08-04-2010, 10:36 PM   #3
Almost all of the interior doors in this house are 30"
I usually install 32" if there is room
2nd floor bedroom I put a 32" door in
Just easier to move stuff in & out
Old 08-05-2010, 01:07 AM   #4
i have seen doors as small as 26" for interior bathrooms, i'm not sure there is any standard rhyme or reason
racebum is offline   Reply With Quote
Old 08-05-2010, 08:35 AM   #5
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
You guys are lucky. My basement door is 27"
I had to take the molding off to fit the dryer through.
CoconutPete is offline   Reply With Quote
Old 08-05-2010, 08:51 AM   #6
Old School
Willie T's Avatar
My bathroom pocket door is 24". Actual clearance is 23 1/4". It's more than enough room... we aren't too fat.
FranÁois Duc de La Rochefoucauld
Willie T
Old 08-05-2010, 09:39 AM   #7
Graphics Specialist
kredman's Avatar
We have a 24" door that goes to one bedroom's bath. It's a tiny one!
kredman is offline   Reply With Quote
Old 08-05-2010, 12:39 PM   #8
Registered User
Rewards Points: 526
http://www.inspectionnews.net/home_i...ning-size.html
http://www.askcodeman.com/viewtopic.php?f=17&t=175
http://www.nachi.org/forum/f18/inter...or-size-26551/
No minimum width, just height.
I did a quick check on the 24", a lot of local Building Departments use that even in attic, garage conversions and basement finishing. Check locally.
Be safe, Gary
Old 08-05-2010, 12:40 PM   #9
Electrician
Proby's Avatar
My bathroom door is 24".
I'm not fat either but my shoulders can't fit thru, so I have to turn sideways a bit.
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-25-2011 11:29 PM
Rule of Thumb for Trowel size and Spacer size please.. K.M.G Flooring 7 02-08-2010 08:13 PM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 12:08 AM
Room size X floor tile size deck hand Flooring 4 04-08-2009 04:42 PM
Minimum garage size? smartin114 Building & Construction 3 03-27-2009 06:46 AM
