Minimum Roof Slope - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-07-2010, 11:56 AM   #1
minimum roof slope
adding a 22 X 14 room to rear of house; mobile,AL south exposure. Ok, pitch if too low for timberline shingles; So, if not shigles, what roof cover do you recommend for best perf.(1-1/2 on12)--bearing in mind that I have to tie it in with the shingles on two sides of flat roof? thanks again.
Last edited by krusader; 04-08-2010 at 09:11 AM. Reason: ans. 2nd "half" of question
krusader is offline   Reply With Quote
Old 04-07-2010, 06:27 PM   #2
Rewards Points: 2,634
Try going to the web page of the shingle manufacturer you are looking at using. They should have a specification of minimum ( and likely maximum ) roof pitch that the shingles should be used on. (might be on the bundle too )
SPS-1 is online now   Reply With Quote
The Following User Says Thank You to SPS-1 For This Useful Post:
krusader (04-08-2010)
Old 04-07-2010, 07:49 PM   #3
Rewards Points: 5,336
Originally Posted by krusader View Post
adding a 22 X 14 room to rear of house; mobile,AL south exposure. limited as to slope (1-1/2 on 12). what is min. pitch for timberline shingles-which matches existing relatively new roof?
If not shigles, what do you recommend for best perf.? thanks!
Shingles require a minimum pitch of 3:12.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
low slope roof want stop leaking kaju Roofing/Siding 22 09-14-2012 12:19 AM
Need ideas for low slope, low priced roof nomechanic Roofing/Siding 1 01-31-2010 01:25 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Venting a shed roof with 2/12 slope atulc Roofing/Siding 5 08-25-2006 07:28 AM
