| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
Fixing Insulation to Save Energy
by Expert Village
We did here in our houses. We have the good insulation but it was not good enough for me. So when we got all these packages from the company's with all these Styrofoam chips in there, we used these chips and put them on top of the ceiling and add to the... Read More »
The Cost of Using a Water Tank
by Expert Village
A tank like this cost you about $1,500 including the pipes, including the faucets and everything you want to use for it. We will just follow now the line of this rain water, how it comes into our house, and you can see how we use it. So what you see here... Read More »
How to Thaw Frozen Pipes
by eHow.com
If you live in a part of the country where the temperature gets down below freezing, you just might run into the problem of having your water or drain pipes freeze. As long as you’re home (and not off vacationing somewhere warm) you can usually fix... Read More »
Checking Ball Valve Installation
by Expert Village
Hi! This is John on behalf of Expert Village. In this video clip, I will be showing you step 6 of installing a ball valve. I am going to go ahead and show you a few tips for soldering. I am going to solder this ball valve on the ground primarily for the... Read More »
Using Rainwater in a Water Heater
by Expert Village
So, we see from back there that the pipe that comes from the water tank, from the rainwater tank, comes in here and then goes into this little pump. And this little pump has a pressure tank in here so that the pressure is always there. Because what we... Read More »
