Old 03-09-2011, 11:49 AM   #1
Question
minimum length for powder room
was wondering what the minimum length for a powder room should be. the simplest design possible with the john facing the vanity and a 24" door opening outside in between the two. my current powder room is 72" long but i think i could go smaller (moving it to a different part of the house).
thanks
Old 03-10-2011, 02:08 AM   #2
you need 30" for the toilet (i refuse to call it a "john"). other than that, i guess you go as small as whoever uses it can squeeze into. submarines have pretty small heads. good luck. john (the other kind)
The Following User Says Thank You to jklingel For This Useful Post:
amakarevic (03-10-2011)
Old 03-10-2011, 03:40 PM   #3
If your door swings in make sure you don't have to climb onto the john to close the door.
househugger is offline   Reply With Quote
Old 03-10-2011, 07:12 PM   #4
LOL, that's why it will swing outside
Insulating a cold/well room? Lynch Building & Construction 22 02-09-2013 08:51 AM
Framing an unfinished basement captainobvious Building & Construction 7 10-16-2009 10:53 AM
Vents from boiler room RammsteinNicCage HVAC 3 03-11-2009 08:28 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
A room in a room? artosie General Discussion 2 03-10-2009 01:43 PM
