Minimum Insulation Requirements? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-19-2007, 03:39 PM   #1
Rewards Points: 152
I framed out a bathroom in my garage (un heated). What is the minimum insulation that I can put in the ceiling?
Can I use R13?
Also what is the minimum ceiling height?
sandyman720 is offline   Reply With Quote
Old 08-19-2007, 05:00 PM   #2
Rewards Points: 5,336
Insulation requirements are regional in nature. To a certain extent, so are height requirements. Try contacting the local building dept. I would have thought the plans you filed would be a hint. You can't just slap in a bath without oversight.
Ron
Old 08-19-2007, 06:19 PM   #3
Rewards Points: 152
I never told them how high the powder room would be nor what insulation would be in the ceiling.
I will call them I guess.
Old 08-19-2007, 10:04 PM   #4
Extreme DIY'r Adk's, NY
Rewards Points: 272
I doubt you can use R13 regardless of where you are.
crecore is offline   Reply With Quote
Old 08-19-2007, 10:07 PM   #5
Rewards Points: 258
Talking
Most of your heat loss through the ceiling. If you live in the northeast you should have a minimum of 12 inch's, up to 16 inch's.There is no point in having more than 16 inch's.
Docfletcher is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Rigid insulation question Endeavor General DIY Discussions 2 07-17-2007 11:27 AM
dormer window insulation wlm-21 Building & Construction 2 02-13-2007 05:04 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
Insulation material reusable? KUIPORNG General DIY Discussions 4 06-19-2006 03:38 PM
