-   -   Minimum Insulation Requirements? (http://www.diychatroom.com/f19/minimum-insulation-requirements-10849/)
sandyman720 08-19-2007 03:39 PM
I framed out a bathroom in my garage (un heated). What is the minimum insulation that I can put in the ceiling?
Can I use R13?
Also what is the minimum ceiling height?
Ron6519 08-19-2007 05:00 PM
Insulation requirements are regional in nature. To a certain extent, so are height requirements. Try contacting the local building dept. I would have thought the plans you filed would be a hint. You can't just slap in a bath without oversight.
Ron
sandyman720 08-19-2007 06:19 PM
I never told them how high the powder room would be nor what insulation would be in the ceiling.
I will call them I guess.
crecore 08-19-2007 10:04 PM
I doubt you can use R13 regardless of where you are.
Docfletcher 08-19-2007 10:07 PM
Most of your heat loss through the ceiling. If you live in the northeast you should have a minimum of 12 inch's, up to 16 inch's.:yes:There is no point in having more than 16 inch's.:no:
