Old 01-10-2011, 11:45 PM   #1
Minimum foam board thickness over OSB
For a mixed humid climate (Arkansas),
what would be the minimum thickness or R-value of foam board over OSB wall sheathing to prevent condensation in the colder months on the inner surface of the OSB when the wall cavity batts are R-19 ?
Thanks,
Arky
Arky217 is offline   Reply With Quote
Old 01-11-2011, 09:02 AM   #2
If you're getting condensation on the interior side of the OSB, it sounds like there is no vapor barrier on the interior(or it's leaking,badly).
Ron
Old 01-11-2011, 01:07 PM   #3
Ron
According to buildingscience.com, no interior vapor barrier should be used for a mixed-humid climate; just the vapor retarding of the latex paint over the drywall. Their reasoning is that the wall should be able to dry in both directions in a mixed-humid climate.
The walls haven't been built yet, I just want to keep the osb board warm enough in the cold months, as per their (buildingscience.com) recommendation, to prevent condensation on the inner surface of the osb.
Old 01-11-2011, 11:13 PM   #4
Moderator
I would not use OSB or R-19; http://www.buildingscience.com/docum...d%20in%20walls
http://bct.nrc.umass.edu/index.php/p...d-and-plywood/
http://www.diychatroom.com/f98/how-b...ulation-90438/
http://www.greenbuildingadvisor.com/...foam-sheathing
Gary
Clothes taking longer to dry?
Adhesive for R MATT foam board captainrichhill Building & Construction 2 05-24-2010 06:40 AM
Concrete over foam board Mudball Building & Construction 16 01-11-2010 11:03 PM
luxaire/york 33109167000 furnace board replacement check HVAC 18 07-13-2009 11:03 AM
XPS foam board between basement slab and cement board for ceramic tiles jpsmith Flooring 4 02-10-2009 09:17 PM
Best way to affix 2" foam board insulation to foundation wall BigJimmy Building & Construction 12 07-21-2008 12:50 PM
