Minimum Distance Between Drywall And Water Pipe - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-21-2013, 09:32 AM   #1
bryanp22's Avatar
Rewards Points: 288
What is the minimum required distance between drywall and a water pipe? I have a pipe in a stud cavity that would basically be flush with the drywall on a wall with my 2x4 studs. Would this pass inspection or do I need to leave some space? Do they make a nail plate that goes across the stud cavity for this purpose?
bryanp22 is offline   Reply With Quote
Old 08-21-2013, 10:00 AM   #2
Rewards Points: 150
I don't think there's a restriction there, only where it goes thru the stud. A nail going thru drywall and hitting a pipe in free air will just tweak to one side or the other... it won't be forced to go straight into the pipe like if you are driving it thru wood where the nail can only go straight and the pipe has no give.
Imagine if such a pipe went vertical... you wouldn't need to sheet metal the entire cavity... and drain pipes in particular often go vertical and fill an entire stud cavity nearly drywall to drywall and that's fine...
SquishyBall is offline   Reply With Quote
Old 08-21-2013, 10:12 AM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 358
Any pipe within 1" of a framing surface needs a nail plate.
This includes plates and studs
Sent from my iPhone using DIY Forum. Watch out for spell check
Old 08-21-2013, 10:15 AM   #4
Rewards Points: 660
Where water pipes or electrical wires go through a stud close enough to the face that a drywall screw could pierce, a nailing plate needs to cover the whole pipe the width of the stud. Your big box stores have the nailing plates.
In the space between the studs, there is no code against being right up against the drywall. If you can help it though, try and get a little distance.
B
Beepster is offline   Reply With Quote
Old 08-21-2013, 10:52 AM   #5
AHH, SPANS!!!
Rewards Points: 1,166
I've seen plenty of drywallers shave the back of the drywall to go around a pipe that sticks into the room to far and they even do not shave it and there ends up being a hump in the wall that I have to fix later
hand drive is offline   Reply With Quote
Old 08-21-2013, 10:59 AM   #6
GBrackins's Avatar
Rewards Points: 2,108
is this a load bearing wall? does the pipe go through the top plates?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 08-22-2013, 04:55 PM   #7
bryanp22's Avatar
Rewards Points: 288
Not load bearing. Top plate is cut out for pipes in this spot. Inspector looked at it and is fine with it as long as I address the fire blocking issue it created removing the top plate. He was fine with filling cavity with roxul to address fire blocking issue.
Old 08-23-2013, 09:40 PM   #8
Rewards Points: 1,428
I put a screw through a vent stack in my new house. If it's a pvc pipe it could easily get pierced.
mikegp is offline   Reply With Quote
Old 08-23-2013, 09:45 PM   #9
bryanp22's Avatar
Rewards Points: 288
It's galvanized pipe for water service. I know it's old but I have no pressure issues and I'm only covering 5 ft of it.
Water Damage: Repairing Ceiling Drywall Defects at Seams? Lovegasoline Drywall & Plaster 5 04-24-2012 07:57 AM
Copper Pipe Leak Caused by Hard Water? Asathd Plumbing 20 07-09-2011 10:06 PM
little bit of water in the basement under the drywall, now what? jailbird371 Building & Construction 2 04-28-2011 07:56 AM
Copper Pipe Water Lines trophywalleye Plumbing 3 03-04-2011 09:44 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
