Old 06-05-2012, 07:55 PM   #1
Minimum deck height above grade
Hello everyone!
I plan on replacing our beat up paver patio with a deck next summer. The problem is trying to figure how low i can make the deck.
Most every framing diagram i find shows the beams resting on the posts, and then the joists resting on the beams. But that would make the minimum height of the deck around 18" above grade. I really need to be no more than 10" or so above grade, (mainly because im tying into an existing screened in porch).
Can i have the joists resting right on the posts, and skip the beams altogether? That would get me pretty close to the 10" max height i need. But i think this might be too bouncy.
I searched and searched for a framing diagram that was close to what i need, but can't find anything
Any thoughts???
Eds_tls is offline   Reply With Quote
Old 06-05-2012, 08:26 PM   #2
Framing Contractor
Originally Posted by Eds_tls
Hello everyone!
Any thoughts???
You install a flush.beam and nail the joist in then put hangers on them.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 06-05-2012, 08:27 PM   #3
robertcdf's Avatar
It's called a flush beam application, the joists HANG (in joist hangers) from the beam much like they hang from a ledger.
robertcdf is offline   Reply With Quote
Old 06-05-2012, 08:29 PM   #4
robertcdf's Avatar
Joe types faster than I...
Old 06-05-2012, 08:29 PM   #5
It was a dark and stormy
Yoyizit's Avatar
Rest the deck on sleepers?
Old 06-05-2012, 09:03 PM   #6
AHH, SPANS!!!
Originally Posted by Eds_tls View Post
Hello everyone!
Any thoughts???
http://www.awc.org/Publications/DCA/DCA6/DCA6-09.pdf
hand drive is offline   Reply With Quote
Old 06-05-2012, 09:47 PM   #7
http://forum.canadianwoodworking.com...feedback/page2
I think the 2nd image down (software drawing) on that link is what you're thinking. You could use short posts or shorter concrete pillars
dbldee20 is offline   Reply With Quote
Old 06-06-2012, 12:46 AM   #8
http://www.google.ca/search?sugexp=c...und+level+deck
A google search on "Ground Level Deck" lots of info
mae-ling is offline   Reply With Quote
Old 06-06-2012, 09:14 PM   #9
Thanks everyone. That answers a ton of questions!
Old 06-08-2012, 12:31 AM   #10
Moderator
Be sure to check the decking material clearance to ground airspace under the joists per manufacturer. Many composite man's require 8" on 3 sides to reduce mold from forming on the surface.
Gary
Clothes taking longer to dry?
Gary in WA is online now   Reply With Quote
The Following User Says Thank You to Gary in WA For This Useful Post:
mae-ling (06-08-2012)
deck surface to door threshold...ideal height?? Sampson Building & Construction 12 11-24-2011 08:07 PM
Deck staircase rail height n0c7 Building & Construction 8 10-23-2011 10:14 AM
Deck Height Issue/ Re-Grading help req.. lepricon_01 Building & Construction 16 06-03-2011 09:24 PM
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 09:39 PM
Deck Staining Nightmare steven994 Painting 2 06-17-2010 08:21 AM
