Minimum Deck Height? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-29-2008, 04:40 PM   #16
Rewards Points: 5,332
Originally Posted by sandyman720 View Post
How would you fasten the double 2x8's to the concrete footings? Do they make special brackets for this?
How many concrete footings would you have on an 18x14 deck?
It seems pretty obvious at this point that you are in need of much more knowledge then can be given here. You need to get a few deck building books and gain a basic knowledge of deck structure and terminology. Once you digest those, come back and fill in any gaps and clarify missed points or confusions in the books. You can also get videos that can help alot at your stage.
You want to understand what your doing and why your doing it so the structure is safe when it's done.
Ron
Old 01-29-2008, 11:12 PM   #17
ecr
i would use 3 2x6's for the beams and 2x8's for the joist. you do not need the center beam this way. you can buy hardware to anchor the beams to the footings.
ecr is offline   Reply With Quote
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 08:39 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
Roof used as a deck - what is a good approach rogersor Roofing/Siding 3 09-19-2007 01:05 PM
Deck Height w/out step DLP600 Building & Construction 4 04-19-2007 11:34 AM
minimum window height mt232 Building & Construction 7 03-24-2007 01:10 AM
