Old 01-28-2008, 03:26 PM   #1
Minimum Deck height?
I am going to build a freestanding deck off of my new addition. The problem is that the door to the addition is only about 15 inches off of the ground.
What size beams and joists can I use so that I can get the top of the deck to line up with my door.
Can I use 2x6's for the beams and joists or is that too small?
I planned to put the 4x4 posts in the concrete and then attach the beams to them very close to the ground (maybe 2 inches off the ground).
Maybe I can get away with 2x6 beams and 2x8 joists.
sandyman720 is offline   Reply With Quote
Old 01-28-2008, 04:20 PM   #2
In a situation like this I would consider a patio rather than a deck. Brick, flagstone, concrete, etc will all last much longer than a deck and you won't have concerns about rodents or dropping jewelry through the deck to an unreachable area.
Old 01-28-2008, 04:30 PM   #3
Windows & Remodeling
HomeSealed's Avatar
2x6's are acceptable, you will just need more beams than with larger joists. The span you can run without a beam depends on the size of the joist. You may want to check with whatever municipality as to what that particular inspector will accept.
HomeSealed is offline   Reply With Quote
Old 01-28-2008, 09:23 PM   #4
robertcdf's Avatar
What dimensions do you want? You can use 2x6 for joists and beams. In fact we are using them for 1 of 2 decks we are building right now.
robertcdf is offline   Reply With Quote
Old 01-29-2008, 12:06 AM   #5
sandyman720 said: "Can I use 2x6's for the beams and joists or is that too small?"
The size of the joist is dependent on the span, not how high the deck is off the ground.
Ron
Old 01-29-2008, 01:14 AM   #6
It would help to know what size you plan to build your deck.
Randell Tarin is offline   Reply With Quote
Old 01-29-2008, 09:44 AM   #7
beam and joist size depend soley on how the relate to span.
RYANINMICHIGAN is offline   Reply With Quote
Old 01-29-2008, 10:03 AM   #8
O.K., so if we know the size of the deck, then we know the span. Or did I miss something.
Old 01-29-2008, 10:03 AM   #9
I plan to make the deck 18x14.
Old 01-29-2008, 10:08 AM   #10
I would use double 2x8's for the beams and 2 x 6's for the joist. How many beams will depend on how you wanted to run your decking.
Old 01-29-2008, 10:52 AM   #11
You missed something. Decks require support underneath. The distance between two supports is the span. You could build a 15'x15' foot deck out of 2x12's and not need additional support under it. But if you build it with 2x8's you would need intermediate support under the structure. It's how the deck is built that defines the span.
Ron
Old 01-29-2008, 02:09 PM   #12
Ok then so let me re-phrase.
If you were to build a 18x14 deck and you wanted the top of the deck to be about 18" off of the ground, how would you construct?
Old 01-29-2008, 02:16 PM   #13
RippySkippy's Avatar
I'm still with jogr....build it on the ground. Opps sorry...didn't see you wanted it 18" off the ground...but still...I'd build it on the ground.
RippySkippy is offline   Reply With Quote
Old 01-29-2008, 02:44 PM   #14
Hellooooo. Double 2x8 BEAMS, AND 2 X 6 JOIST= SUPPORT
Old 01-29-2008, 05:26 PM   #15
How would you fasten the double 2x8's to the concrete footings? Do they make special brackets for this?
How many concrete footings would you have on an 18x14 deck?
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 09:39 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
Roof used as a deck - what is a good approach rogersor Roofing 3 09-19-2007 02:05 PM
Deck Height w/out step DLP600 Building & Construction 4 04-19-2007 12:34 PM
minimum window height mt232 Building & Construction 7 03-24-2007 02:10 AM
